Search instead for
New MX Products!
New MX Products!
Meraki just launched a few new MX products: MX250, MX450 and Z3. See here: https://meraki.cisco.com/products/appliances#mx-new
MX250 is rated for 4Gbps of throughput while the MX450 is rated for 6Gbps. The Z3 is rated for 100Mbps and includes Wave 2 AC wireless and a PoE port.
MRCUR | CMNO #12
Re: New MX Products!
Nice new additions to the MX portfolio. Don't forget the vMX100 for Azure! It's good to see the teleworker getting an update to be able to keep respectable standards.
Thanks.. can you please share the detailed datasheet of the new devices?
All datasheets are available in our library (meraki.com/library)
Here are the specific datasheets:
(MX) https://meraki.cisco.com/lib/pdf/meraki_datasheet_mx.pdf
(Z Series):https://meraki.cisco.com/lib/pdf/meraki_datasheet_z_series.pdf
Thanks Tony. How about updating the MX Sizing Guide to include MX250 and 450?
The Z3 looks sweet. I've been wanting PoE in the Z series for a while!
@Polymathink It works really nicely. Wireless on it is also surprisingly quick. Very pleased with it so far.
MRCUR | CMNO #12
Just browsing
When will the Z3 be orderable?
Hi AlexB, Z3 will be available end of the month. Thanks for your patience!
Will the MX250 accommodate a 1Gig SFP for WAN or only 10Gig?
@B_TylerYou can use a 1Gb SFP in either WAN port.
MRCUR | CMNO #12
Hi Tony
I have some mobile applications for the Z3. If we do not use the Poe capability, what specification power supply can we use?
