EDIT:Sorry, I didn't mean to yell. When I post it changes the format to bold and caps.
I just found the answer to my own question I think. But leads to another question with this note.
NOTE: Customers cannot downgrade from Advanced Security to Enterprise Licensing.
Can I beak up my Org after the fact then downgrade? Create one for advanced security and one for enterprise. What will that break?
MX Licensing Options
The MX Security Appliance has two license editions: Enterprise and Advanced Security. Please note that the MX licensing edition is uniform across the Organization. For example, you can have all 25 appliances using Enterprise Edition or Advanced Security Edition, but you cannot have 20 appliances using one edition and 5 using the other edition. If you wish to use Enterprise Edition for some appliances and Advanced Security Edition for other appliances, you need to create two Organizations, one for your appliances with the Enterprise Edition, and another for the appliances with the Advanced Security Edition.
