Network isolation
Towhid
Just browsing
Network isolation
I wanted to isolate my wifi vlans with my network I don't want any communication between both of them if iam at my wifi vlans I don't want my ip to communicate with lan vlan or RDP how do I configured it
11 Replies 11
Shubh3738
Use “Layer 3 Firewall Rules” on the MX
Go to Security & SD-WAN → Firewall & traffic shaping → Layer 3 firewall rules
Add a rule to block traffic between Wi-Fi VLAN and LAN VLAN:
Policy  Protocol       Source                           Destination          Port/Range
Deny   Any             VLAN 20(Wifi VLAN)     VLAN 10(LAN)        Any
Make sure this rule is above any allow rules, because Meraki applies rules top-down.
This will prevent Wi-Fi clients from reaching LAN devices (including RDP, file shares, etc.)
Towhid
Just browsing
I tried this as well still the issue was still there
Shubh3738
Shubh3738
Then try- Option B: Use “SSID Firewall Rules” on the Wi-Fi SSID
Go to Wireless → Firewall & traffic shaping → SSID firewall rules
Add a rule like:
Deny Any Any Local LAN Any
This isolates Wi-Fi from LAN without affecting LAN-to-LAN routing.
Brash
L3 firewall rules are what you need to setup.
You will want to deny rules for your WiFi clients to prevent them communicating with your other clients.
You can apply these rules on the MX, or on the MR SSID. Where you apply these will change how clients can talk to each other.
https://documentation.meraki.com/General_Administration/Cross-Platform_Content/Using_Layer_3_Firewal...
One thing to note is that L3 rules on the MX don't impact site to site VPN destined traffic. You would instead need to use site to site VPN firewall rules
https://documentation.meraki.com/MX/Site-to-site_VPN/Site-to-site_VPN_Firewall_Rule_Behavior
jimmyt234
Have a look at the layer 2 isolation and outbound rules section on the SSID Firewall & traffic shaping page.
Wireless Client Isolation - Cisco Meraki Documentation
Towhid
Just browsing
Why it's not related to layer 2 how would it make any difference
jimmyt234
Because you'd want to isolate clients on the same SSID so they cannot access each other????
Towhid
Just browsing
We don't have MR we only use MX for firewall can we use group policies to isolate netwrok
Shubh3738
So, where you have created the SSIDs.
