Need help with setting an external DDNS for my MX64
FelixWong
I recently purchased a NAS for my home use and I would like to have my NAS found with a domain name.  However, I do not have a static IP address, therefore I'm looking at using the services from NO-IP.
And the problem begins, my MX64 is xxxxx-gcjdzzbgjh.dynamic-m.com.
I would like to have my MX64 display my domain.  How should I go about doing it?
Anyone help?
Felix
You could use a CNAME from your domain to the DDNS entry.
9 Replies 9
FelixWong
thanks for the reply.
It worked!!
fmarcoux96
@FelixWong wrote:
Anyone help?
Felix
As pointed by @PhilipDAth, you can use a CNAME to point an existing subdomain or domain to your Meraki FQDN.
However this implies another DNS query for each time you access it. If you want, I have build a PHP script used to ping the Meraki address, get the IP and set it on a Cloudflare DNS. This way, I have my own DDNS service.
If you are interested in that script, let me know.
PJCRUX
I would be.
fmarcoux96
See my reply below.
roger779
Thank you so much,
Best Regards
roger779
Hello good day, could you please share the scrip with me?
Best Regards,
Roger
fmarcoux96
PJCRUX
Thank you what is the steps for install? Or how did you accomplish it?
