Need ability to test VPN setups on internal network before sending staff home
dirttmcgert
Just browsing
I am trying to find documentation somewhere on how to set up an MX64 to allow vpn connections from the internal network. My boss doesn't like the fact that we aren't able to test it on the machines before employees take them home because the 1 in 20 that need a little extra help connecting are causing too much downtime. I know there should be a way. I just can't find it. Any help would be greatly appreciated.
6 Replies 6
KarstenI
The "right" way to test is to use it as the users do. Connect the test pc to a cellular hotspot and connect to the outside interface.
dirttmcgert
Just browsing
I agree, but the boss doesn't like that solution...
CptnCrnch
Your boss doesn't like working solutions? 😲
What about getting an additional cheap domestic Internet circuit to use for testing?
If you have a range of static IPs, connect the device on a different IP and come on from there to the MX.
nealgs
we do it the same way as @PhilipDAth mentions.
We have a standard fibre BB connection from BT (we are in the UK) that we use to connect our test kit to meaning we can test them out before sending/deploying to site.
cheap solution 🙂
