NULL route on MX
rsage_voda
NULL route on MX
Is it possible to configure a NULL route on a MX to prevent routing Loops.
I have a site with a /14 supernet from which smaller subnet are used for the various services supplied at site. There is a static route 10/8 to the MPLS network. The customer is running a Tenable scanner in Azure via the MPLS across all subnets in the /14 which is resulting in routing loops. To stop this I want to add a static route to a null interface for the \14.
If I add a static route for the /14 with the next hop 0.0.0.0 the dashboard throws an error that the address 0.0.0.0 is not on a configured interface.
RWelch
If your goal is just prevent specific subnets / destinations from being reached, you might consider:
Security & SD-WAN > Configure > Firewall then add Layer 3 outbound rules to deny traffic to ?.?.?.?/14 (or certain IPs)
NO, it's not possible.
DarrenOC
As already stated, not possible with MX or other Meraki devices.
Do you have anything before/after the MX where you can blackhole the traffic?
Depending on the number of sites you have, would replacing the 10.0.0.0/8 with a series of /14 networks instead work?
route 10.0.0.0/14 ...
route 10.4.0.0/14 ...
route 10.8.0.0/14 ...
route 10.12.0.0/14 ...
route 10.16.0.0/14 ...
