NDR in Meraki Environment
bmessinachicago
Hoping to get some insight as to what others might be using along with their Meraki MX firewalls for deeper reporting and analysis of their network from a security standpoint. I have been looking at some NDR products, just not sure if there might be a solution or strategy that tends to be preferred out there.
Thank you!
2 Replies 2
CptnCrnch
Talking about integration with MX, typically a Flow-based approach is the easisest choice. As @PhilipDAth already mentioned, there's Secure Network Analytics that handles this really well.
Other products typically take another approach that "forces" you to install their appliances into your DC and connect them to Span ports and the like.
