NBAR on Combined Network
abunch06
Good Morning,
I noticed that with MX16.16 that NBAR was added as a feature. When digging through the Meraki documentation on this feature, I'm a little confused.
I'm seeing that you have to have MX16+ for the feature to work, but that the feature only works on MS390 switches and Wifi 6 AP's running MR27+.
So does this mean that if I have a network with MX16+, an MS120 switch and MR42 AP's (801.11ac) that NBAR will not work?
How about on a network that uses MX16+, an MS120 switch, and MR44's? Does the MS390 requirement disable NBAR totally or will it still work for wirelessly connected devices?
Thank you!
1 Reply 1
