NATting traffic with a 3rd party VPN peer due to subnet overlap
Tokerau
Just browsing
I'm new-ish to the MX routers. We need to create a VPN between our MX and a non-Meraki router. Our subnet is 192.168.0.0/22.
I was told by the 3rd party that our networks overlap (apparently they se the same subnet) so they asked if we could NET our traffic to a different IP subnet.
In looking at the 3rd party VPN peer setup, I can't figure out a way to do this.
Is this done on the Site to Site VPN config screen or somewhere else? Can it be done at all?
Thanks!
1 REPLY 1
You cant do that, its only for auto vpn.
So the other side has to do it. Or you can change your subnet
https://documentation.meraki.com/MX/Site-to-site_VPN/Using_Site-to-site_VPN_Translation#Consideratio...
