I have two internet service providers. On WAN1 i would like to enable NAT. On WAN 2 I would like to it to be on pass through mode.
How do i achieve this?
Solved! Go to solution.
After letting Meraki-support enable the NAT-exemption feature, you can selectively disable NAT per WAN-port and even per VLAN.
Works good. With one customer I habe a direct internet-line on WAN2 with NAT, but on WAN1 the ADSL-router in front of the MX is doing NAT, so I disabled NAT on that port.
You probably don't want to have the "Meraki Passthrough" mode which would work as a L2 bridge on a single WAN and routed mode on the other? That is not supported.
Please provide meraki support email address
On your dashboard go to Help -> Cases (top right corner) and open a new case for this.
Thank you. Meraki engineers managed to assist
As @Karl mentioned, you will need Meraki support to assist in enabling the No-NAT feature.
You can then change this per uplink or per VLAN.
