Multiple user groups or IP pools for AnyConnect using Azure AD SAML
harmankardon
Hi all,
Looking to find out if there is anything new in the art of per-user access control for AnyConnect VPN, i.e. user groups or multiple IP pools etc... when using AnyConnect and Azure AD SAML auth.
In short, I'd like to apply a specific set of L3 firewall rules to some but not all AnyConnect users.
I know about the group policy method in which you wait till the user connects, find them in the Clients list and then apply the policy, but that is tedious and I believe has to be re-done if they age-out of the client list.
I also know there is a way of doing this using the Filter-Id attribute if you are using RADIUS auth, but nothing like that for SAML auth as far as I can tell.
JamesT91
There is a private beta for Azure SAML group policy matching based on responses from the IdP - email meraki-anyconnect-beta@cisco.com to request they enable the feature on your MX.
The only way is to use the filter-ID via Radius.
JamesT91
harmankardon
Interesting, this is the first I've heard of this, thanks for the heads up. Have you been using this beta feature and what are your thoughts on it?
JamesT91
Unfortunately I never got as far as trying it!
