Search instead for
Multiple defaults routes priority ?
I want to implement network with 2 default-gateway for the internet connection. one primary and a secondary route. We can configure the static route to be active only while a host respond, but i can configure that first route be the single route while the host respond ?
Thanks you,
Regards,
2 REPLIES 2
DN
Re: Multiple defaults routes priority ?
I beleive the simplest way to do this is to add the both routes with different administrative distance on your core router , that will pass the data to the gateway .
For example ,
ip route 0.0.0.0 0.0.0.0 xxx.xxx.xxx.xxx   ======> Primary
ip route 0.0.0.0 0.0.0.0 xxx.xxx.xxx.xxx  10  ======> Secondary
I hope this is what you were looking for .
Do you have the possibility to connect those two connections to a separate uplink? Because then you can just use Load Balancing features:
https://documentation.meraki.com/MX/Firewall_and_Traffic_Shaping/MX_Load_Balancing_and_Flow_Preferen...
