Multiple VPN on Meraki
Abhishek2
Can we configure multiple VPN profiles? According to Meraki guides it says only 1 Subnet is allowed. What is the best way to configure multiple VPN?
For ex: Client 1 subnet 10.0.0.0/24
             Client 2 subnet 192.168.100.0/24
2 Replies 2
Brash
You're correct, Meraki client VPN only supports a single subnet. It is fairly limited in its features.
If you need to restrict some clients from accessing some parts of the network, you will need to do so using group policies.
Create multiple Client VPN for Multiple Network - The Meraki Community
Meraki also supports Cisco Anyconnect VPN, which can provide additional features and profiles, but only one subnet for address pooling. Note that this does however require an additional license.
AnyConnect on the MX Appliance - Cisco Meraki
KarstenI
My solution would be to add an additional Firepower Device to the setup.
