Multiple Site-to-Site VPN connections
lmorel
Hello, I am trying to set up multiple Site-to-Site VPN connections from multiple on-premises sites to a single AWS VPC. I have done this years ago in Azure successfully and can see a single entry under the non-Meraki VPN peers entries. Then in Azure I created the multiple connections with same password and everything worked out ok.
I am now in my AWS VPC console under the Site-to-Site VPN Connections menu and I am trying to figure out how I am supposed to do this. Am I missing something?
I would prefer not to use a vMX at this point as I have my VPC and its environment up and running to already connect to one site via site to site VPN. I am trying to add more MX sites to connect to that same AWS virtual private gateways. How do I accomplish that?
Brash
It's a bit old but as far as I'm aware this guide should still be accurate
A Visual Guide to Setting up a Meraki to AWS Site-to-Site VPN – RIT Computing Security Blog (wordpre...
By default when configuring the non-meraki VPN peer, it applies to all MX's in your org.
Shubh3738
@lmorel
Deployment options
This Partner Solution provides the following deployment options:
  •          Deploy Meraki VMX into a new VPC. This option builds a new AWS environment that consists of the VPC, subnets, NAT gateways, security groups, bastion hosts, and other infrastructure components. It then deploys Meraki VMX into this new VPC.
  •          Deploy Meraki VMX into an existing VPC. This option provisions Meraki VMX in your existing AWS infrastructure.
Also go through with below documents.
https://documentation.meraki.com/MX/MX_Installation_Guides/vMX_Setup_Guide_for_Amazon_Web_Services_(...
https://aws.amazon.com/quickstart/architecture/cisco-meraki-vmx/
lmorel
Thank you so much for your replies. I ended up figuring it out. Maybe I wasn't clear in my original post. I managed to get S2S setup. But trying to do multiple S2S to a single VPN in AWS was challenging to me. Until I found posts from others about using the tag feature under the Availability tab in Meraki dashboard to separate the ipsec profiles.
Solved: Multiple IP Sec SIte to SIte VPN on a Single Dashboard - The Meraki Community
