Mulitcast traffic over Meraki MX VPN
Joe2112
Greetings -
I have a scenario where a customer has two campuses - main and branch. The main campus has a primary 4GB Internet connection via a non-Meraki firewall and a backup Internet connection using business cable modem with a Meraki MX used here. The branch campus has a 10GB, point-to-point dark fiber back to the main campus and its own business cable connection with a Meraki MX connected to it. There is a 'backup' connection using a site-to-site VPN between the two sites using the cable connections and Meraki MX appliances. (see diagram).
The customer uses multicast traffic to send audio broadcasts from the main campus to the branch campus. This works fine until the 10GB fiber connection goes offline. Normal IP traffic works but we cannot get multicast traffic across the VPN connection using the Meraki MX appliances.
Is multicast traffic across a Meraki MX site-to-site VPN connection supported? If not could I use a GRE tunnel across the site-to-site VPN?
Any information/input is greatly appreciated.
Cheers
Hey @Joe2112 ,
Like @NolanHerring said the MX cannot route multicast traffic, so you cannot forward it over the AutoVPN. But yes, if you had another external device that could do multicast routing you could GRE tunnel it between two endpoints through the AutoVPN tunnel. This could be either a L2 or L3 GRE depending on how you wanted to do it. Unfortunately, Meraki does not support GRE, so you need to look elsewhere for that.
5 Replies 5
NolanHerring
https://documentation.meraki.com/zGeneral_Administration/Other_Topics/Multicast_support
IGMP Support on the Cisco Meraki Security Appliance
MX Security Appliances will forward IGMP traffic for a single broadcast domain. It does not forward multicast traffic upstream, between VLANs, or over a VPN.
Nolan Herring | nolanwifi.com
TwitterLinkedIn
I suppose if you were able to encapsulate the traffic 'before' the MX, then the MX won't know what it is, so you could send it across that way. In theory...in my head. No clue if there is a way to do that though lol.
TwitterLinkedIn
Hey @Joe2112 ,
I am going to look further into what hardware the customer has deployed behind the Meraki MX appliances and see if they support GRE tunnels.
Thank you the information.
Cheers
Joe
Buy Sonicwall...... They support multicast over VPN, I’m using them in a mission critical environment to send radio audio between a 911 center and a remote radio in the field about 30 miles away.... they have been in service for about 4 years and have never needed rebooted. I think its right up your alley!
