If you use Objects and Object Groups, it'll be a bit more complex, as you'll have to keep track of the IDs, assuming you'll be moving rules between organizations. It it's between networks within the same organization, it shouldn't be much difficult, other than you'll need to keep track of the source networks. If I remember correctly, the source ip network, needs to exist in the Meraki Network for it to work.
LinkedIn :::
https://blog.rhbirkelund.dk/Like what you see? - Give a Kudo ## Did it answer your question? - Mark it as a Solution
🙂All code examples are provided as is. Responsibility for Code execution lies solely your own.
