Moving firewall rules to another MX - The smoothest way? - Except a SS that support suggested :D
DavidR
So except a screen shot - easiest way to move an MX?
Well I actually have two MX so I can set up the other first and then copy all settings?
No export?
Boundless Digital also sell a tool for doing this.
https://www.boundlessdigital.com/product/migration/
14 Replies 14
rhbirkelund
No Export per se. You would use the API to get the rules, and post them to the other MX.
DarrenOC
This is the way.
rhbirkelund
If you use Objects and Object Groups, it'll be a bit more complex, as you'll have to keep track of the IDs, assuming you'll be moving rules between organizations. It it's between networks within the same organization, it shouldn't be much difficult, other than you'll need to keep track of the source networks. If I remember correctly, the source ip network, needs to exist in the Meraki Network for it to work.
RaphaelL
Clone the network
DavidR
OK Hmm
Can you clarify exactly what you are doing?  Is this an in-place upgrade, or something else?
DavidR
I am moving an MX67 to another organisation (and network) but want to keep all the firewall settings.
Is it a new Organisation, or does the organisation already have Meraki networks configured?
If it is then split the current combined network into constituent parts, re-combine the non-MX networks if you want to and then ask support to move the MX network to a new org with the license.  I'm pretty certain they will do that.
Here is a link to the documentation, MXs aren't on the not allowed list:
Organization Split Overview and FAQ - Cisco Meraki Documentation
TNAComputers
I know its on the doc, but I also think its worth again mentioning that if the org that you are moving out of has subscription licenses, nothing can be done. Short of APIs to gather objects/ACLs etc, licensing, org splits etc will not work. The only choice is to start over with a new org/network and copy manually or use APIs like @PhilipDAth provided below to export/import.
I found this out the hard way during an acquisition where the previous company gave us access to the current org to just that network, so I couldn't tell what licensing they were using. Normal emailing support to split the org and found that there was nothing we could do but start over since it was subscription licensing.
In the Meraki GitHub, there is a script for exporting and importing firewall rules between Organisations.
https://github.com/meraki/automation-scripts/tree/master/mx_firewall_control
There is also a network migration script that could be worth a look.
https://github.com/meraki/automation-scripts/blob/master/migrate_networks/migrate_networks.py
All the network automation scripts are here:
DavidR
Wow thank you SO much for all this help!
I dont even know that suggestion to mark as a sulotion ❤️
