Monitoring Spoke Performance
RaphaelL
Hi ,
I'm just wondering how do you monitor your spoke performance ?
Monitoring hubs is pretty straight forward , there are far fewer devices. Using the endpoint getDeviceAppliancePerformance makes a lot of sense. However when you have 1200 branches , this will eat up a lot of your api calls. We are already on the verge of hitting the rate limit.
We would need getOrgAppliancePerformance which would give the performance score of all devices in a single org but that endpoint doesn't exist yet.
So I'm curious , how do you manage that task ?
Is there no MIB that you can use on Zabbix?
I'm not sure ! I have checked the MIB very quickly the other day and I could't find anything related to that.
Documentation on state API , but I could be mistaken : https://documentation.meraki.com/MX/Monitoring_and_Reporting/Device_Utilization
I just checked, and it's not possible via SNMP, so annoying. 😕
Yeah that would be a nice api.
You could use the top 10 and focus on f.e. everything above 70+%
https://developer.cisco.com/meraki/api-latest/#!get-organization-summary-top-appliances-by-utilizati...
Or use the dashboard summary page
