Modifying a port on a template affects all ports - MX
Hi folks ,
I have been through a strange behavior.
We have a Security appliance template with some ports with 802.1X enabled and some on a Open access policy.
When I applied the 802.1X policy on a open port ( on the template) , ALL the ports went into a reauth or something like that. Result : 300-400 phone calls droppped and phone were unregistered for a solid minute.
This is what support responded :
( which I was unabled to reproduced in my labs.. )
Unfortunately, this particular outage is expected behavior. In order to make sure that all of the devices are properly authenticating to the ports. Making changes to the ports that are using radius causes the MX to reevaluate ports that use radius. So even though you were just modifying 12, the MX needed to revaluate 11 as well which caused the phone to go down.
Some models do a port reset on all ports when you make any port change. It is one of the reasons I use loop free cabling configurations (as opposed to using dual links) because it causes spanning tree to re-compute knocking out the network for 30s a time.
I've had more short outages caused by making configuration changes when I used to use dual connections than I have had cable/port failures ... the HA causes more outages than it prevents.
LITHIUM.InformationBox({"updateFeedbackEvent":"LITHIUM:updateAjaxFeedback","componentSelector":"#informationbox_7b6cbf934ca78","feedbackSelector":".InfoMessage"});
LITHIUM.InformationBox({"updateFeedbackEvent":"LITHIUM:updateAjaxFeedback","componentSelector":"#informationbox_7b6cbf934ca78_0","feedbackSelector":".InfoMessage"});
LITHIUM.InformationBox({"updateFeedbackEvent":"LITHIUM:updateAjaxFeedback","componentSelector":"#informationbox_7b6cbf934ca78_1","feedbackSelector":".InfoMessage"});
LITHIUM.InformationBox({"updateFeedbackEvent":"LITHIUM:updateAjaxFeedback","componentSelector":"#informationbox_7b6cbf934ca78_2","feedbackSelector":".InfoMessage"});
LITHIUM.AutoComplete({"options":{"autosuggestionAvailableInstructionText":"Auto-suggestions available. Use Up and Down arrow keys to navigate.","triggerTextLength":4,"autocompleteInstructionsSelector":"#autocompleteInstructionsText_7b6cbf44af932","updateInputOnSelect":true,"loadingText":"Searching...","emptyText":"No Matches","successText":"Results:","defaultText":"Enter a search word","autosuggestionUnavailableInstructionText":"No suggestions available","disabled":false,"footerContent":[{"scripts":"\n\n;(function($){LITHIUM.Link=function(params){var $doc=$(document);function handler(event){var $link=$(this);var token=$link.data('lia-action-token');if($link.data('lia-ajax')!==true&&token!==undefined){if(event.isPropagationStopped()===false&&event.isImmediatePropagationStopped()===false&&event.isDefaultPrevented()===false){event.stop();var $form=$('
