Mixing 68w and MR 44
BigK
I have a sd-wan solution that has a MX 68w and MR 44
I configured the VPN on the 68W and the VPN status looks Green
  • VPN Registry: Connected. This WAN appliance is able to connect to multiple VPN registries using UDP port 9350 & 9351.
  • NAT type: Friendly. This WAN appliance is behind a VPN-friendly NAT, locally using 192.168.8.11 :56859, which is NAT-ed to 132.15.4.12.5:14671
  • Encrypted. Using IPsec and AES encryption.
All SSID on the 68W are disabled.
I connected 2 X MR 44s to POE port and the ports are green
When I plugged in the MR 44 new network automatically appeared in the dashboard called wireless
I configured the SSIDs on the MR 44
The MX 68 status shows the ports connected, but the wireless network shows down..
any help is appreciated it
From what I understand, the status of your APs is down on the dashboard, correct?
Just wait for a while and it will soon be online.
Do the APs show as online in the dashboard?
The issue with AP not coming up earlier was due to the port was 802.1x and it was enabled. now that the port is open, the AP is online and the SSID is enabled and visible to the users, however there is a DHCP failure. Not sure if the DHCP should come from external (windows server for the MX68 or internal).
