I've inherited a network stack consisting of Meraki MS switches and an active/standby ASA 5508-X pair with firepower which sit on a primary fibre line with secondary ADSL backup. My current understanding is that the line fail over is handled by the WAN providers gear.
Long story short, I've not come across a mixed meraki switch and asa environment in such a small estate and in truth, the ASA configuration is overkill for what the client needs.
Has anyone had experience of moving from ASA and firepower, across to Meraki MX units in a similar active standby pair?
Is it easy enough to configure the Meraki units whilst the ASA units are still in use then switch everything over?
