Meraki to Azure for multiple sites
MerakiStig
I have 3 sites that currently link via a VPN.
In addition i want to connect them to Azure through a non meraki VPN peer.
In Azure i have created a virtual network, a virtual network gateway, 3 local virtual networks and a connection for each local virtual network.
On this virtual network is a virtual machine
In meraki i created a non meraki VPN peer for site 1 which connected.
I can also RDP connect to the virtual machine.
This is working
The issue im having is then when i setup a non meraki VPN peer for site 2 it breaks the connection for site 1.
From my understanding its because the connection is exactly the same, Same Public IP going to the same private subnet, I've just done it on a different network on the Meraki portal.
I thought being done on a different site network in meraki wouldn't impact the other.
Anyone done this before any know how to resolve it?
You need a tunnel for each site, it means 3 tunnels on Azure.
Can you elaborate?
I already have 3 local networks setup in Azure each with their own connection.
Issue is all 3 local networks connect to the same virtual gateway network so the non meraki vpn setup is to the same public IP and subnet.
Site 1 is connected from meraki to azure
I can not connect the other 2 without breaking site 1
Resolved my own issue...
Set site 1 form spoke to hub
Tagged all networks
Changed each Meraki to Azure VPN connections from all networks to their own tagged network.
I now have 2 sites working, connecting to Azure without breaking
