Meraki MX450 Update from 17.10.2 to latest, second fail and fallback
PinkyandBrain
Just browsing
We had this week our second fail in updating our MX450 from 17.10.2 to latest Firmware.
After the Update takes place and the MX450 is back in Network some setting is causing a complete network loop that stops everything from working.
After Fallback to 17.10.2 everything is directly back to business?
Checked meanwhile all Patch notes but nothing makes a real clue what new feature or wrong configuration will cause a loop???
Help very welcome.
Our second firewall in a different branch MX100 updates without any problem and is meanwhile at latest version.
I think it would be a good idea to open a support case.
JohnT
We have the same problem with our MX95 cluster.  I guess the cluster loses track of who the primary node is and chaos ensues.  We opened a support case and they want to test a new firmware.  Unfortunately, we can't test until the end of September because we can't have our network meltdown again during a 24/7 operation.  The other suggestion they had was to break the cluster and upgrade independently and then rejoin.
PinkyandBrain
Just browsing
Thanks for your comment. Please report back if the "Beta" Firmware will work.
We opened also a technical Support ticket.
Let´s see what happens...
