Meraki auto VPN can still be established? if add Layer 3 firewall Rule to deny all
newnovice
Hi all,
as subject title, if we add deny any any rule in Layer 3 firewall, does Meraki auto VPN can still be established successfully? Thank you in advance.
KarstenI
Yes, the Firewall rules on the MX are for traffic that is sent through the firewall to the outside or to other VLANs. It doesn't affect traffic to or from the MX.
1 REPLY 1
KarstenI
