Meraki VPN MFA / Multifactor authentication
EamonnT
Hi everyone,
I'm new to the community,
has anyone successfully setup dual factor / multifactor authentication when Using VPN to connected to  corporate networks. We just had a security audit and its one of the things they pointed out to us.
Look forward to your reply's !!
Happy new year to all!
1 Reply 1
KarstenI
There is no native integration with any MFA providers. You can use any system that uses *one* login through RADIUS and divides this login to authenticate both factors.
I use duo.com for this:
  1. User enters his AD-credentials
  2. MX sends the login to the Duo authentication-proxy (an app running on Windows or Linux)
  3. The Auth-Proxy uses this login to authenticate the User to Active Directory (or through ISE)
  4. When the Authentication is successful, the Auth-Proxy queries the Cloud to send a request to the smartphone
  5. The user accepts the login on his smart-phone
  6. The user is granted access
