East-West Firewall Protection
ricvil
The MX appliances have a pretty attractive set of advanced firewall features in the Advanced Security License.  My question is, do the appliances protect against spreading east-west malware for example?  As long as we plug in the LAN devices into available ports directly in the MX and all are in the same VLAN, does the MX actually inspect same VLAN traffic or does it simply switch it?
Thanks,
Ricardo
Bruce
As Karsten stated, if the traffic is in the same VLAN then there is no inspection. If you’re passing traffic between VLANs then the MX firewalls apply as well as the IDS/IPS rules, but not the AMP - that only applies to traffic arriving directly on the WAN/internet port. So the MX can be good for macro level segmentation for a small server farm (where you can put each server in its own VLAN), the greatest limitation may by the throughput of the MX appliances (which Karsten’s suggestion of a Cisco Firepower may ‘fix’)
If you’re wanting to provide inspection for all traffic within a data centre, along the lines of micro segmentation, then l’d be looking at other technology. Something like Cisco ACI can achieve that, or there are options depending on what hypervisor you are using (e.g. VMware NSX).
KarstenI
My last test (some time ago) showed no inspection for intra-VLAN traffic, but IPS is applied for inter-VLAN traffic. But I did not test transparent mode.
I would asume that for this usecase, there is not enough flexibility for tuning on the MX. I would look for a firepower appliance.
Bruce
ricvil
Understood.  Thanks for the insight.
