Meraki Network Monitoring
amalmichaelvj
Hello Guys,
How can i monitor the Meraki Devices .Which Software should i use.?
My setup.
////We have MX firewall, MS Switches, MR Access Points. One of my administrator will monitor the device status ,Internet down, Wireless disconnection.
Do i get any email notification if any of devices down?
For DHCP conflict for Wireless ,Wireless Disconnection?
internet Connection Down?
email alert for these issues?
Am looking for a solution which i can monitor with aditional screen/ or software? We are monitoring from different location? not on premise.
Anyone Familiar with this setup?
You can set up all these alerts from the dashboard, they can email multiple emails addresses and each alert category can have a different list if you want.
amalmichaelvj
Thanks for details. Email part is ok. I will check the confi part.
Other than Meraki dashboard, Is there any other method for monitoring ??
We are monitoring from different location? Office is in Abhu dhabi and we are monitoring from Dubai??
Maybe it will help you.
https://apps.meraki.io/en-US/apps/412728/zabbix
What does the dashboard not provide that you would need?
