Meraki MX84 Configuration fail
JohnS86
Hi All
I have issue with a customer where we configure our Meraki MX84 but it failed to pull the Meraki configuration from the cloud and end up going a continuance reset loop.
We been told by Meraki helpdesk that this is knowing issue and where able to fix it.
Has anyone seen this issue before and if so can advise how to fix it
John
6 REPLIES 6
CptnCrnch
You should be able to reset the MX to factory defaults, afterwards it will pull the latest config from the cloud:
https://documentation.meraki.com/zGeneral_Administration/Support/Resetting_Cisco_Meraki_Devices_to_F...
Can we fix it without doing full reset on the MX84 and are Cisco going fix this issue as it on their end that causing the issue
antonis_sp
If support cannot fix this remotely, then you will have to reset the device yourself.
I've only had this issue with random APs so far. Some were fixed by the support team, some had to be reseted manually.
route_map
I had this issue with my MX64, event after i tried to reset it wouldnt work, just loop all day long.
I had to log a case for support to reset it on their side
Hi
Yes that what happen to us
Wondering if there a better solution
route_map
but it doesnt take long to get it sorted
