Meraki MX450 VPN HUB loss table
SopheakMang
Dear Expert ,
As i have checked with the dashboard , i see the Meraki MX 450 uplink ( VPN-CON)
seem loss percentage around this :
loss.PNGThis VPN hub handle branches now around 70 branches , and this is the loss percentage of the uplink during the production , from the time 18:00 to 8:00 is the non-working hour. so just focus on 10:00 to 18:00 , is this normal ?
Could you help advise ?
Accepted Solutions
rbnielsen
Re: Meraki MX450 VPN HUB loss table
I suppose.
This is my MX64 at home, behind an ADSL modem.
The more traffic there is, the more packet loss I'd expect. I doubt most people work during evening and night, and thus not as much traffic as there would be during normal working hours.
6 REPLIES 6
rbnielsen
That curve shows ping statistics from the WAN port to (most probably) Google DNS 8.8.8.8.
So I would probably assume something between the MX and upstream is dropping icmp packets.
Aside from checking L1 at the MX (verify cabling is properly connected, no damage to cables, no dirt on SFP/fiber connectors), I'd open a ticket with your service provider, to verify it isn't something on their end.
However, unless you or your users are experiencing any degraded service, I'd probably just leave it alone and monitor.
SopheakMang
Hi ,
Thanks for your response , I see it is under 1% , is that normal as well ?
rbnielsen
I suppose.
SopheakMang
Thanks for ur explain as well bro!!!
rbnielsen
No worries. 🙂
But like I said, if there is no degraded performance, and no-one complains, then there probably isn't that much of a problem. I'd just monitor for now. 🙂
Uberseehandel
To be honest, I'd wonder if the data being aggregated and reported is statistically accurate. For example missing data points should not distort what is reported.
I'm not talking about Meraki, but I do know of another Bay Area networking hardware and software company that produces great looking charts, most of which are b.s., because the software developers have no regard for data science, database design, or statistics and drop alpha hardware and software of customers and let them find the problems. Checking the data is a low priority. Customers are mostly happy, they like dynamic graphics.
