Meraki MX250 Credentials ??
Snika
Connect your PC to the Meraki MX250's MGMT port and the setup dashboard will pop up.
But the login credentials are not logged in with Serial number.
Before adding the MX250 to the meraki dashboard inventory, login with the serial number worked fine.
Does connecting to dashboard change credentials?
Brash
Once the device has connected to Meraki cloud, the credentials will change from default to whatever is set under  'Network Wide > Configure > General > Device Configuration'
1 Reply 1
Brash
