Meraki MX105 client VPN capacity
Arif4869
Dear Concern,
One of our customer have total 500 client VPN user. But con-current client VPN user is 50-100. Can we go with MX105 based on this requirement? Also clear the information about the maximum client VPN capacity. For MX105 the maximum client VPN is 250. My question is it con-current or total?
KarstenI
Yes, you can go with the MX105 if the rest of the specs fit your needs.250 is the recommended amount of Client VPN tunnels which corresponds to concurrent users.
The total amount of VPN users is relevant for AnyConnect licensing. If you go for the PLUS subscription, you need to licenses 500 users for AnyConnect.
MX 105 is recommended for mid to large enterprise locations with 750 users simultaneous including VPN clients.
And the commended VPN client tunnel is 250 user simultaneous
Inderdeep
@Arif4869 : It is for Concurrent users
https://documentation.meraki.com/MX/MX_Overviews_and_Specifications/MX95%2F%2F105_Datasheet
Regards/Inder
www.thenetworkdna.com
