I'm in the process of modifying our network, and I noticed that I'm getting this in the event log. I know vlan: 3 is for VLAN 3, which is correct, but what does vap: 0 mean? Apparently, it's for wireless, but I have a MX68, and it doesn't have WiFi. Just wondering what this means, and how can I fix it?
"vap: 0, vlan: 3"
I think I know the answer. Right now, we have everything on VLAN 1 on our Cisco router. But, I have a Meraki test network in my office which is using VLANs (2,3, and 4), so I guess my laptop is connecting to our existing WiFi network, which is on VLAN 1, and the Meraki is confused because on the Meraki, there's no VLAN 1?
Am I right?
Solved! Go to solution.
It's normal. All my DHCP leases appear like that in the event log too. It just tells you that the MX has handed out IP address x to client y.
Is there anything else on that log entry? Seems incomplete...
vap: 0, vlan: 4, ip: 172.16.129.3 « hide
router | 172.16.128.1 |
subnet | 255.255.192.0 |
dns | 172.16.0.25 172.16.0.26 |
duration | 86400 |
server_ip | 172.16.128.1 |
server_mac | 12:34:56:78:90 |
This is for VLAN 4, but same type of message, vap: 0
Okay, so it's a log line for a dhcp offer on vlan 4. That MAC address, do you recognize it? How is that device connected?
I made up that MAC address. So how can I fix the message? Is it normal?
ok thanks
