@MRCUR wrote:
Are you thinking of changes that would cut of the device's Internet connectivity? Typically the devices won't actually apply the new config unless it successfully gets out to the Internet with the updated settings (although it may just be doing a simple ARP check which wouldn't necessarily indicate Dashboard connectivity).
I too am curious about the use case here. The only config change, like you mentioned, that I could see being a problem would be the WAN connection(s). I'm not sure a watchdog timer or something similar would be a good idea - if you had an outage, it might get stuck rebooting a million times thinking it was "offline".
You could always ship devices with 4G USB, for out of band management. Or, if you have another method for out of band management, use the management port.
BHC Resorts IT Department
