Meraki MX Warmspare
V_007
Meraki MX Warmspare
Hi All,
1) Can we configure warmspare between 2 MX using single usable ip address and both Mx will use same ip for dashboard communication i.e 1.1.1.0/30 where 1.1.1.1 will be gateway (Mux ip) and 1.1.1.2 will assign to both MX
2) If not can we use the lan routeable ip address receive from Service provider to assign to both MX individual ip address and one virtual ip address of same subnet will share by both Mx
Wan link terminate on Meraki Mx from Mux will be 115.24x.151.0/30
Lan routable ip address will 136.23x.176.0/29
Hi @V_007, unfortunately not.  You need at least two, but you can put a NAT device in front of them to achieve this.  I don't think option 2 will work either, but it might, others have more experience here.
3 if he wants to use virtual IP.
https://documentation.meraki.com/MX/Deployment_Guides/MX_Warm_Spare_-_High_Availability_Pair
V_007
Would i required to follow the same while assigning Lan ip address to MX i.e Individual ip on both MX with one vip or both MX will have same ip Lan address to serve internal traffic.
Just one LAN IP
