Meraki MX Public IP Change
navysubvet
My MX105 was previously configured with the same IP as the legacy firewall. I have other public IPs available, but I'm worried about losing connectivity (I'm several states away). For that reason, I'm hesitant about pulling the trigger. What are my chances?
CptnCrnch
Quite good from my point of view. At least if you don‘t screw up the default Gateway 😇
Are you changing the public IP address to another in the same existing subnet?  If so, you should be fine.
BlakeRichardson
Just kidding, as mentioned if its within the same subnet it should be a piece of cake.
