Meraki L7 Firewall Rule on Client VPN Traffic
Basha1996
Hi Team,
We have AnyConnect configured on Meraki with the client routing only for our internal network segments. We want to enable L7 rule in Meraki Firewall for blocking traffic for a specific country. We know that the internal traffic will not hit the firewall and it take s2s vpn path, however wanted to double check if the L7 rule takes effect for the client vpn traffic.
If you are using split-tunnel yes, otherwise no.
Client Routing: This is used to specify full or split-tunnel rules pushed to the AnyConnect client device. You can send all traffic through VPN, all traffic except traffic going to specific destinations, or only send traffic going to specific destinations.
https://documentation.meraki.com/MX/Client_VPN/AnyConnect_on_the_MX_Appliance#How_to_Enable_AnyConne..._Dashboard
You can also apply this via Group Policy.
Basha1996
exactly, in our setup we are using only send traffic to our internal  segments 10.10.0.0/16. so the L7 rule will not take effect on this right .
Malwina
You could test with Group Policy assignments for your AnyConnect users
https://documentation.meraki.com/MX/Client_VPN/AnyConnect_on_the_MX_Appliance#Group_Policies
