Meraki Devices Uptime on Dashboard
MXBEGINNER
Good Day,
I am using MX-68 security appliances . when I reload my devices some time devices active immediately on dashboard and everything is ok, but sometime it take too long like 2 hours to be active on dashboard.
Last night I reload my devices one of them be active after 5 minutes and the second be active after 4 hours on dashboard.
I want to know why this happen and how to overcome this issue..
Regards:
KB
2 Replies 2
rwiesmann
hi,
usually a reboot of an MX goes quite fast if the internet connection is o.k you should be able to connect
within 10 min I would say.
Did you change maybe the Uplink configuration and then reboot?
There is a mechanism to revert to the last safe configuration...so if you change the Uplink and do a reboot and after the reboot there is no internet connectivity due to the uplink change...the MX will revert to the last safe configuration after some hours.
See also:
https://documentation.meraki.com/General_Administration/Cross-Platform_Content/Behavior_during_Conne...
rgds
roger
You would need to check the local status page on a device experiencing a connectivity issue to see what it is reporting.
Most likely, it is having trouble communicating with the Internet or a DNS server.
