Meraki Cloud license renewal
tantony
I got an email saying that I need to renew my Meraki Cloud license in 90 days.  How can I view the quotes for 1 year or 3 years?
I send an email to my Meraki rep, but no reply.
6 REPLIES 6
KRobert
Re: Meraki Cloud license renewal
Did you purchase directly from Meraki or through a 3rd party vendor? Typically they can provide the quote history. If you would like to know the cost at MSRP, you can use the Meraki Calculator here: https://meraki.cisco.com/buy/cost-calculator
CMNO, CCNA R+S
tantony
I used 3rd party vendor recommended by Meraki
KRobert
I would definitely reach out to them then and see if they can provide more accurate 1 and 3 year quotes. They can most likely provide more accurate pricing than the Meraki Calculator page, but The cost calculator is helpful when having those budgetary conversations.
Hope this helps @tantony!
CMNO, CCNA R+S
BlakeRichardson
@tantony  You will need to contact the reseller you used last time, Meraki don't sell licenses directly as far as I know.
JohnnyMeraki
Meraki Alumni (Retired)
Contact your Cisco Meraki reseller and they will be able to provide you with quotes. You might want to check out this promotion as well: https://meraki.cisco.com/firstyearonus/en (not for license renewals however, but one extra year doesn't hurt if buying new products).
KRobert
Hi @tantony,
I hope this helped solve your issue. @JohnnyMeraki made a good point to mention the https://meraki.cisco.com/firstyearonus/en which provides additional cost savings. Unfortunately Cisco's EoY is at the end of July so you wont be able to receive any potential EoY savings.
CMNO, CCNA R+S
