We're migrating to the Cisco Community on March 31. The Meraki Community will enter read-only mode starting on March 26 through March 31.
Solved! Go to solution.
https://community.meraki.com/t5/Security-SD-WAN/Phase1-and-2-VPN/m-p/84677
They don't give info on what exactly they are using for autovpn. You can see what ports are needed at help> firewall info
Some other info here
@PhilipDAth
