Meraki | Auto Email Alert WAN1/WAN2 Down
Lloydie
Hi Cisco Community,
Good day!
I would like to ask for some suggestion/help/recommendation on how I can manage to have an email alert once WAN1 or WAN2 is down.
Email alert will only send once WAN 1 and WAN 2 is down for almost 2hours.
Tried this configuration but seems to be no time indicated once it goes down/up it will send alert to the default recipients.
Most usefull without meraki insight is:
Alerts-> Security appliance -> "The primary uplink status changes"
With meraki insight you can set wan1/wan2 alerts
https://documentation.meraki.com/MI/Alert_Management_in_Meraki_Insight
Lloydie
Thanks for the reference.
Will check and test it.
Just wondering where can we find the secondary uplink status change.
So you need insight for that, Or make some script that uses the api to check wan status
Lloydie
Thank you so much for this.
Will study about this and try it to implement.
