Meraki AP & Radius Integration
SLR
Hello -
I have been working a test network to get Meraki AP with Radius integration based on instructions in below youtube video. I found when I followed this video, I was not successful in my setup unless I removed the TunnelPvt-Group-ID (vlan number) attritube from the configure radius attributes piece. Once I removed that, I was able to get my devices connected to the wifi with WPA2- Enterprise (my radius server) User credentials are validated with 802.1X at association time
I also did not use vlan tagging
Is this approach not correct?
https://www.youtube.com/watch?v=mMSSfy_mIlQ
2 Replies 2
SLR
that is exactly what it was. We were using VLAN override. I just wanted to be sure that I was doing it correctly. I had the following set up:
1
Tunnel-Type = "VLAN",
2
Tunnel-Medium-Type = "IEEE-802",
3
Tunnel-Private-Group-ID = "128"
I kept the 1st two attributes and then removed the third one. Everything worked as it should.
