Meraki 67c
Aamir
Meraki 67c
Can we now make sd-wan tunnels over the 4G builtin SIM the "c" MX devices like MX67c?
1 Reply 1
Ryan_Miles
Is the 4G link the only WAN connection or in addition to a wired WAN link? If it's the only link then AutoVPN works by default. If you have a wired WAN link and want to use both that and the internal cellular link you can enable the Cellular active uplink feature and then use WAN 1 & the cellular link for AutoVPN/SD-WAN.
https://documentation.meraki.com/Architectures_and_Best_Practices/Cisco_Meraki_Best_Practice_Design/...
