Meraki 67 Port Forwarding for DVR
MicahLackey
I am very new to this process and could use some help!!
I was following the instructions from https://documentation.meraki.com/MX/NAT_and_Port_Forwarding/Port_Forwarding_and_NAT_Rules_on_the_MX
When I try to put "Any"  under Allowed IP's and try to save I get an "error saving page"
I have a CBS350 connected to this and have set up port 18 with a lan ip and need to know how to point this rule there
MicahLackey
Thanks, everyone for the  replies. I found out that my access rights were not set correctly
5 Replies 5
There is no secret:
MicahLackey
That is what I did but I get an error message and it will not save. Now this is a Lorex dvr model LH118000. that wants to use port 80 but I am changing to 8080 and it also uses 9000. I know there is an issue with using 80 and that is the reason for change
I suggest you open a support case.
Can you post a screenshot of your configuration and error when saving it?
Make sure you have filled out all the fields.  Make sure the local IP address belongs to a local network on the MX.
MicahLackey
