Measure temperature on Meraki MX64W
Restrada
Hi everybody, i'm looking for a way to measure the temperature on the Meraki MX64W specifically via snmp, i need to polling the temp, fan speed (if it's present in) and also traffic of the interface. somebody know, which are the specific oid that o need for this job? and also if i can do it via my own lan or it need be via the meraki cloud
I don't believe you can measure temperature or fan speed..
MerakiDave
I don't believe you'll be able to poll that data via SNMP unfortunately, but check with Support when you have a moment, they have a way on the back-end to check certain settings (like fan speed) on the switches, not sure about MX appliances but worth checking.
Adam
I know for sure support has that visibility on switches but not sure on the MX.  I still think it would be nice to expose that kind of device health info in the dashboard.
