We have traffic shaping setup on one WAN1 (100MB) port and later procured a larger throughput link (WAN2 1 GB) is there a simple way with minimal downtime to move the uplink and traffic shaping or is a physical cable swap the best approach? I am new to Meraki and have spent most my time with Cisco routers. We essentially want WAN2 to become WAN1 and maintain the traffic shaping on WAN2 as it has 1 GB throughput because the 100 MB WAN1 is being saturated.
My mind sees this as a cable swap but if there can be a config change instead that is more ideal. Is there a way to ensure the config is swapped with no loss in traffic or missed lines of configuration?
If you are load balancing , I don't see the need to swap the cables. As stated just adjust the settings in your flow preferences / Shaping and uplink selection
LITHIUM.InformationBox({"updateFeedbackEvent":"LITHIUM:updateAjaxFeedback","componentSelector":"#informationbox_3d8e5c9f57c9c4","feedbackSelector":".InfoMessage"});
LITHIUM.InformationBox({"updateFeedbackEvent":"LITHIUM:updateAjaxFeedback","componentSelector":"#informationbox_3d8e5c9f57c9c4_0","feedbackSelector":".InfoMessage"});
LITHIUM.InformationBox({"updateFeedbackEvent":"LITHIUM:updateAjaxFeedback","componentSelector":"#informationbox_3d8e5c9f57c9c4_1","feedbackSelector":".InfoMessage"});
LITHIUM.InformationBox({"updateFeedbackEvent":"LITHIUM:updateAjaxFeedback","componentSelector":"#informationbox_3d8e5c9f57c9c4_2","feedbackSelector":".InfoMessage"});
LITHIUM.AutoComplete({"options":{"autosuggestionAvailableInstructionText":"Auto-suggestions available. Use Up and Down arrow keys to navigate.","triggerTextLength":4,"autocompleteInstructionsSelector":"#autocompleteInstructionsText_3d8e5c97345ffe","updateInputOnSelect":true,"loadingText":"Searching...","emptyText":"No Matches","successText":"Results:","defaultText":"Enter a search word","autosuggestionUnavailableInstructionText":"No suggestions available","disabled":false,"footerContent":[{"scripts":"\n\n;(function($){LITHIUM.Link=function(params){var $doc=$(document);function handler(event){var $link=$(this);var token=$link.data('lia-action-token');if($link.data('lia-ajax')!==true&&token!==undefined){if(event.isPropagationStopped()===false&&event.isImmediatePropagationStopped()===false&&event.isDefaultPrevented()===false){event.stop();var $form=$('
