Ran into an issue on Friday that I'm going to research further tomorrow. Tried swapping out a Sonicwall firewall with HA setup with two MX85s. The sonicwall is setup with one physical port that splits into multiple virtual ports for each VLAN. When I installed the MX85 I set the MX up with Trunk native vlan 1 as the default setting is. When I connected to the netgear switch from what I could tell is that only vlan 1 and possibly only on first switch was working. The netgear switches are tagging all VLANs but VLAN 1 is untagged.
Should I change the netgear to untag all VLANs?
I didn't have too much time to test because I ran out of time on my outage window for the client.
Anyone ever run into MX to Netgear setup like this?
