MX85 - crash logs
Volcomer
MX85 - crash logs
We have a setup of 2 MX85's in hot spare, that has worked just fine for about a year and a half now. Recently the primary has started crashing for no apparent reason about once a week, not logging VRRP transition and rebooting. This causes a short, but annoying, outage for the entire building while we wait for the spare to pick up the slack. When the Primary comes back up the VRRP transition back to primary works seamlessly without any outage.
I am trying to find out why it crashes, and maybe how to remedy this, but I can't find any crashlog or system log at all, and the eventlogs for the device are just blank during this timeframe, so it's like it never happened. Are there really no system logs we can get a hold of to find out why a device crashed?
Brash
The dashboard event logs are typically pretty bare bones.
You can get a bit more info by logging to a syslog server, but for something like this, you're best off logging a case with support who can usually pull up the details and logging of a crash from the backend.
5 Replies 5
You need to open a support case.
The problem is the Support Data Bundle from the local status page has to be downloaded before the reboot.
You could try setting up a syslog server.
Or maybe set the standby as primary.
But i would create a meraki case and maybe they can replace the device
Brash
SnarkySharky
We're also experiencing this and opened a support case.  This is a known issue the development team is investigating.  You should open a support request as well so the issue gets prioritized.
cnuc
We do have the same issue with an MX85 customer appliance which is crashing once a week, tested with several firmware versions. Meraki support told us, that this is a known issue and that there is currently no fix.
