MX85 WAN2 Won't Connect.
official_damo
My client has an MX85 with the 2x copper WAN ports used for redundant internet services, both are enterprise static IP services.
The WAN2 port has never worked, after some troubleshooting I determined the carriage service is operating fine and the Meraki config is correct. We reconnected the service to Meraki and, as before, we see the physical port UP but no layer3 connectivity (Status: Not connected).
I raised this with support and was told "There is a know issue about the WAN 2 of the Mx85 that deliver PoE power to an un-PoE device."
Has anyone come across this issue before? It seems odd to me that there is a 'known issue' which prevents this device from performing a primary function and it needs be sent to R&D for a fix, it's also concerning (if true) that the issue was already known and a fix was not being worked on.
Interested to hear other peoples experience, this is the only MX85 I manage so I have no frame of reference.
Brash
What firmware version are you running?
I have multiple MX85's running 17.10.x and 18.107.x versions with both WAN ports online.
Other than that;
Do you have any SFP's plugged into the SFP ports?
When you statically assign the IP address, can you reach your assigned default gateway?
If you do a packet capture, do you see the packets leaving the MX?
official_damo
Firmware: MX 18.107.2.
No SFPs.
I cannot ping the gateway as the port shows as not connected.
I can't perform a capture as the interface is no shown in the list.
If I connect another device to the providers equipment the service works fine.
NicT
Did you ever figure this out? I have the same issue on an MX85.
