Cisco Secure Client VPN allowing Local LAN
DRichardson
Hello All,
Our Parent company has rolled out Cisco Client VPN. For the most part, everything is fine, but our users can no longer print or talk to a different VLAN unless disconnected from the VPN. Our set up has VLAN 2 (Main network for users) talking to VLAN 5(Printers). We have the Cisco VPN Client set to allow Local LAN access when on VPN. The users can only talk to devices on VLAN 2 at this point and not VLAN 5. Wanted some thoughts on this... New to this.
1 Reply 1
MartinLL
You would need to do some sort of split tunneling since VLAN 5 is not a "local LAN" for your clients.
If Secure Client is configured on a vMX you can go to the client VPN tab on your VPN headend, select anyconnect and scroll down to Client Routing. There you can add the network to traffic exceptions for example.
MLL
