MX84 master and spare for just 1 ISP only.
Lucas_T
Good day,
I have 2 mx84, as well as 1 ISP. Can anyone share the setup's entire configuration? Now that my main FW is operating properly, I am unable to set up my spare FW.
Will it work on 1 ISP only?
Thank you~
KarstenI
One ISP is no problem at all as long as you have a /29 network assigned.
If you don't have, there was just a discussion this week:
https://community.meraki.com/t5/Security-SD-WAN/HA-MX-Assign-same-ISP-address-to-both-MXs/m-p/187191
Lucas_T
Thank you so much Karstenl, i will try it.
@Lucas_T  as explained by @KarstenI  you need a /29 network assigned, If you wnat configure public IP on WAN interfaces.
The only way to use the same public IP is using a NATed IP. Take a look at my example, I only have a single public IP, but my wan interface is configured with a private IP, i.e. it's behind a NAT.
Lucas_T
Thank you so much Alemabrahao!
